C sharp script help
C sharp script help
hi all,
I have been looking on line and found a c script for emailing via gmail a file but not sure how to integrate into scene, so I can email snap shots using the script.
using System;
using System.Windows.Forms;
using System.Net.Mail;
namespace WindowsApplication1
public partial class Form1 : Form
public Form1()
InitializeComponent();
private void button1_Click(object sender, EventArgs e)
try
MailMessage mail = new MailMessage();
SmtpClient SmtpServer = new SmtpClient("smtp.gmail.com");
mail.From = new MailAddress("your_email_address@gmail.com");
mail.To.Add("to_address");
mail.Subject = "Test Mail - 1";
mail.Body = "mail with attachment";
System.Net.Mail.Attachment attachment;
attachment = new System.Net.Mail.Attachment("your attachment file");
mail.Attachments.Add(attachment);
SmtpServer.Port = 587;
SmtpServer.Credentials = new System.Net.NetworkCredential("username", "password");
SmtpServer.EnableSsl = true;
SmtpServer.Send(mail);
MessageBox.Show("mail Send");
catch (Exception ex)
Console.WriteLine(ex.ToString());
using System;
public Form1()
try
Re: C sharp script help
Hi Hashim,
I'm still in the early stage of C# but ive been having a go at this
I think i found the post that you referenced your code from and i couldn't get it to work in visual studio, so i picked up another bit of code and had a go with that
I have successfully sent email from visual studio with this code so have transferred it in to Ventuz to do some testing.
after some hours of compiling errors in Ventuz i have now got a code that is returning zero compile errors in the script node (getting there
But.....and its a big but.....i still haven't been able to send a test email from Ventuz......
So I too am now wondering if anyone can point out where this script is going wrong in order to achieve said task
See attached file
If theres any prob with attachment, heres the code so far.....
added to Validate()......
inputs added to script node:
strings: YourEmail, SendToEmail, EmailPassword, Subject, EmailBody
Bool: Update
Outputs added to script node:
Strings: Exception, MessageSent
using System.Net;
using System.Web;
string SendersAddress = this.YourEmail;
string ReceiversAddress = this.SendToEmail;
string SendersPassword = this.EmailPassword;
string subject = this.Subject;
string body = this.EmailBody;
try
SmtpClient smtp = new SmtpClient();
smtp.Host = "smtp.Gmail.com";
smtp.Port = 587;
smtp.EnableSsl = true;
smtp.DeliveryMethod = SmtpDeliveryMethod.Network;
smtp.Credentials = new NetworkCredential(SendersAddress, SendersPassword);
smtp.Timeout = 30000;
MailMessage message = new MailMessage(SendersAddress, ReceiversAddress, subject, body);
smtp.Send(message);
this.MessageSent = ("Message Sent Successfully");
this.Exception = (ex.Message);
changed = true;
hopefully we can get this sorted
Chris
p.s didn't get attachement working either, which i know is what you want the script for.......so any ideas on that would be awesome
See attached file
Bool: Update
using System.Net;
using System.Web;
try
smtp.Port = 587;
smtp.Send(message);
changed = true;
Chris
oooops.....forgot file
- GmailFromVentuz.vza
- (6.96 KiB) Downloaded 682 times
It works fine for me just paste your code in a method created via the CustomModel.
Cherio!
Cherio!
It works! excellent! cheers Daniel (got your email
now i will have a look at the attach file option and come back with a working answer....hopefully
chris
chris
add this just before .......smtp.send(message);
attachment = new System.Net.Mail.Attachment(@"C:\Users\the file URL goes here");
message.Attachments.Add(attachment);
solved.....
Chris
solved.....
Chris
Nice bit of scripting which as a new C# user I could just about understand.
Does your render stall when sending the email? How can this be avoided?
Answering my own question...
Simple really, use sendasync to send the mail!
cool iv'e tried to understand the sendasync, looking at link
http://msdn.microsoft.com/en-us/library ... async.aspx
but i have no idea how to add to script any help
