I'm currently looking at a show for a client which requires a 10 projector widescreen blend resulting in a 14880 x 1080 pixel space!
This will be one continuous image which we will be playing back content at the full resolution.
The full screen curved around the audience so screen shaping will be in play here.
I wanted to call on your experience here for some pointers
At the moment my thoughts are to split the load across 3 Ventuz servers.
2 will be outputting 3 x 1920x1080 via ATI V8800
1 will be outputting 4 x 1920x1080 via ATI V8800
Each will have HDSDI input cards for camera images and ATI S400 cards for gen/framelock
Does this seem like the best set up? or with such large content is it better add another server to spread the load?
Has anyone tried to push content this large through a Ventuz cluster?
How good is the edge blend in Ventuz? do you have any control over the gamma in blended regions?
and finally... the manual says that it is better to use a single machine if possible. Is it even conceivable that for this large a screen space with such large content, that i could use a single machine running a V8800 and just add a Datapathx4 to 3 of the outputs and achieve this??
My feeling is that the playback at this resolution would be too much for a single system!
Any thoughts or tips appreciated
Chris
