Hello all,
I am trying to trigger a crossfade between two external audio sources connected to a USB audio interface which is being driven by Propellerhead Reason. I can send MIDI commands from Ventuz to Reason, that 'snap' between the two mixer channels, but I would like to achieve a smooth crossfade, which would require continuous MIDI values to be sent. Does anyone have any ideas how to do this with Ventuz?
Many thanks in advance.
Paul
Continuous MIDI for audio crossfade??
Re: Continuous MIDI for audio crossfade??
i guess that you are using some kind of interpolating node to generate the smooth fade values (eg. mover/linear/damper) but only press 'send' at the beginning and end of the fade.
you can connect this value with an Int node and use the 'changed' event to trigger the Midi-out 'send'
this will generate multiple midi messages per second, making the crossfade appear smooth.
Thank you Schub, thats just what I was after.
Paul
Paul
