If you got markers on the screen and those are registrated at the Marker's TouchInside and you save your scene
then the TouchInside Flag is still true after reloading the scene. A Reset (on Scene Activation) doesn't help out.
One Question about the Marker: Why does it have those "crazy" coordinates instead of providing 0-1 like in tuio?
I don't really understand the calc, because the other interaction nodes provide other ranges.
Wouldn't it be possible to have a Bool to choose between Output "calculations"/passthrough? Would be helpful.
Bug in Marker Node
errox
Re: Bug in Marker Node
Hi Alex,
it is still happening in the current version. That problem also occures when interfacing a hierachy container that contains a marker node.
But if I do so and my render window's size is changed the X,Y values get a new range... a little bit tricky.
Btw is it possible to get somehow the rendersize in an info node (to recalc the division)?
But with the device I use I need to devide through 3690000 (x) and 1167000 (y), its resolution is 1920x1080...
Thats why I would prefer normalized values to get the "right mapping".
Greets Nico
I can comprehend that when I use sth like the "reactivion tuio simulator", dividing values through my resolution I get my 0-1.The node internally uses 0-1 and multiplies it by the screen's size to provide absolute pixel or something like that.
I really like that idea!! It would be nice to choose between screen-space/"object-space"/normalized!It might be possible to create such an "object-space"-mode as well for the marker node and return as X/Y the closest approximation of translation to match the screen position of the marker. what do you think?
Greets Nico
