2 little beginner questions:
Bounding Box Values:
Is there a way to get the bounding box values of a subtree? I figured out seen you can manipulate and dictate the values via the Volume node, but is it also possible to simply read them out?
Project Repository:
Don't know whether it's really a bug, so I also post it here:
I built a hierarchy container, made it interfacing and moved it into the repository, then created several instances out of it. > "Update all Containers" works fine
Then I created a subfolder in the repository and moved the template into it. > Update doesn't work anymore...
Did it really lose its reference to its instances due to the subfolder or have I messed it up some other way?
Martina
