Instagram Shader
Posted: 07 Jul 2012, 15:47
To create this kind of "look" you need to use a renderpass as texture for an overlay shows in the image below
the code for the shader are
// postwendend.com
// kontakt@postwendend.com
// published under:
// http://creativecommons.org/licenses/by-sa/3.0/
// variables
sampler2D post_img;
bool sw;
float r = 1;
float g = 1;
float b = 1;
float r_contrast = 1;
float g_contrast = 1;
float b_contrast = 1;
float brightness = 1;
float contrast = 1;
bool ca;
float ca_r = 0;
float ca_g = 0;
float ca_b = 0;
bool vigenttierung;
float radius = 10;
float darkness = 1;
// pixelshader
float4 cc( float2 Tex : TEXCOORD0 ) : color0
// define the texture
float4 color;
if (ca)
//input.UV = (input.UV - scaleCenter) * scale + scaleCenter;
float2 tex_ca = Tex;
float2 center = float2(0.5f, 0.5f);
tex_ca = (Tex.xy - center ) * (ca_r/10+1.0f) + center;
float4 color_r = tex2D( post_img, tex_ca);
tex_ca = (Tex.xy - center ) * (ca_g/10+1.0f) + center;
float4 color_b = tex2D( post_img, tex_ca);
tex_ca = (Tex.xy - center ) * (ca_b/10+1.0f) + center;
float4 color_g = tex2D( post_img, tex_ca);
color.r = color_r.r;
color.g = color_g.g;
color.b = color_b.b;
else
color = tex2D( post_img, Tex.xy);
// brightness + contrast for each r g b channel
color.r = (((color.r -0.5f) * max(r_contrast, 0)) + 0.5f)+(r-1.0f);
color.g = (((color.g -0.5f) * max(g_contrast, 0)) + 0.5f)+(g-1.0f);
color.b = (((color.b -0.5f) * max(b_contrast, 0)) + 0.5f)+(b-1.0f);
// brightness + contrast for all channels
color.rgb = (((color.rgb -0.5f) * max(contrast, 0)) + 0.5f)+(brightness-1.0f);
if (vigenttierung) {
float2 inTex = Tex - 0.5;
float vignette = 1 - dot(inTex, inTex);
color.rgb *= saturate(pow(vignette, radius) + darkness);
if (sw)
color.rgb = (color.r + color.g + color.b ) / 3;
return color;
technique post
pass p1
VertexShader = null;
PixelShader = compile ps_2_0 cc();
