NLE Support.
Posted: 01 Feb 2012, 18:23
by PhillK
I've been searching the old forum for more information into what the ventuz solution is for rendering in an NLE situation iwithout much luck.When time is critical and live machines are needed to operate in parallell to a fast turnaround for an edit what do you guys recommend? Are there any NLE plugins on the horizon or is there any more information on rendering to a video clip (avi or otherwise).
Multiple Threads
Posted: 06 Feb 2012, 07:51
by pilot78
Does SWF player support multiple screen playback in 1 osx machine ?
I want to connect 2 32" screens to 1 mac mini, and show 2 different flash movies on the screens. Possible ? or do i need 2 different players then ?
Re: NLE Support.
Posted: 10 Feb 2012, 10:59
by ErikB
PhillK wrote:Hi,
You can render into an image sequence. I would guess you could do a capture directly into a NLE though, as well (either a DVI capture or via SDI).
However that really is not the pipeline we generally are in (the whole point of Ventuz is to be real time... there are probably more suitable tools for doing motion graphics if you don't want to be realtime). The only case where this is generally a requirement is to send a previz to someone. For that, generally you would render the image sequence, which you then load into whatever system you'd like.
