Live video node
Posted: 25 Apr 2012, 12:01
by javier
Hi, I'm trying to use my laptop in the node Live video, but whenever I select to add Ventuz closes. I used it on other computers and it works, but my laptop does not work even if I change the camera or capture card. Any ideas?
Re: Live video node
Posted: 03 May 2012, 09:29
by Daniel Willer
Hi could you please post your designer.log file located in %HOMEDRIVE%\ProgramData\Ventuz.
Cheers!
Re: Live video node
Posted: 03 May 2012, 11:39
by javier
Hi Daniel, I've been looking for the file but can not find it. Is it in this folder should be?
Re: Live video node
Posted: 03 May 2012, 12:34
Just copy the path that Daniel posted to your Windows Explorer!
Re: Live video node
Posted: 03 May 2012, 17:26
by javier
Is this what you need?
18:19:50.6 Info : Ventuz Starting Ventuz 3 Professional Designer V3.06.01 as 32bit process on Microsoft Windows 7 64bit
18:20:23.3 Info : Remote listening to Port 19200
18:20:23.3 Info : Shaping listening to Port 19200
18:20:23.4 Info : CLI listening to Port 19201
18:20:23.4 Info : VertigoXMedia listening to Port 4000
18:20:23.4 Info : OscRemote listening to Multicast 230.230.230.230 on Port 19230
18:20:23.4 Info : Remote Remoting2 listening to Port 19200
18:20:23.4 Info : Remote Remote Render-To-Disk listening to Port 19200
18:20:23.9 Info : Input Subsystem Using single machine setup.
18:20:23.9 Info : Input Subsystem Windows Touch is enabled.
18:20:23.9 Info : Input Subsystem Listening to Port 3333 (TUIO)
18:20:24.0 Info : Device Selecting Device #0 (NVIDIA GeForce 610M , \\.\DISPLAY1)
18:20:24.0 Info : Device Multisampling Best: 16x
18:20:24.2 Info : Clock Local timing 60,00fps
