Page 2 of 2
				Re: fisheye-foto on a hemisphere
				Posted: 16 Jan 2014, 11:32
				by stephan
thanks a lot for spending your time and help Karol!
Yes, Paul Bourke is a great dome specialist ...
Stephan
				Posted: 04 Jun 2015, 18:06
				by dondi
				Stephan,
Were you ever able to find a solution to your problem? Would be interested to see what you came up with.
-- Dondi
				Posted: 05 Jun 2015, 06:46
				by stephan
				Hi Dondi,
unfortunately no success. So we decided to create a non-interactive standard video.
Tools: AEFX + Navegar-plugin.
(won two gold awards
 s )
Greets, Stephan
				Posted: 05 Jun 2015, 08:35
				by lerou
as already pointed out, you need a special geometry for that with the correct UVs.
Also the mapping must match your fisheye effect as fisheye is a pretty general word - it mostly means catching an unusually high angle.
A special case is a hemisphere map, where you have an angle of 180°. That is easy to map. I've attached an example for that special case.
With your sample picture it won't look perfect. With a hemispherical map it does. You could fetch such an image from the web to try it in the attached scene. For instance
this picture.
cheers,
				Posted: 05 Jun 2015, 12:20
				by stephan
				job is done, nevertheless I will test it.
Thanks a lot
Stephan
				Posted: 05 Jun 2015, 19:11
				by lerou
				there's always the next job...
