fisheye-foto on a hemisphere
stephan
Re: fisheye-foto on a hemisphere
Post by stephan » 16 Jan 2014, 11:32
:D
thanks a lot for spending your time and help Karol!
Yes, Paul Bourke is a great dome specialist ...
Stephan
dondi
Post by dondi » 04 Jun 2015, 18:06
Stephan,
Were you ever able to find a solution to your problem? Would be interested to see what you came up with.
-- Dondi
stephan
Post by stephan » 05 Jun 2015, 06:46
Hi Dondi,
unfortunately no success. So we decided to create a non-interactive standard video.
Tools: AEFX + Navegar-plugin.
(won two gold awards :D s )
Greets, Stephan
lerou
Post by lerou » 05 Jun 2015, 08:35
as already pointed out, you need a special geometry for that with the correct UVs.
Also the mapping must match your fisheye effect as fisheye is a pretty general word - it mostly means catching an unusually high angle.
A special case is a hemisphere map, where you have an angle of 180°. That is easy to map. I've attached an example for that special case.
With your sample picture it won't look perfect. With a hemispherical map it does. You could fetch such an image from the web to try it in the attached scene. For instance this picture.
cheers,
hemisphere.vza
(363.73 KiB) Downloaded 495 times
stephan
Post by stephan » 05 Jun 2015, 12:20
job is done, nevertheless I will test it.
Thanks a lot :D
Stephan
lerou
Post by lerou » 05 Jun 2015, 19:11
there's always the next job...
