Post
by chriss0212 » 03 Jun 2016, 13:23
in Ventuz4 there was an option to set default parameters for min/ max etc. in v5 the inherit checkbox is gone
greets
Post
by Karol » 03 Jun 2016, 14:07
Mine is still there!
Can you post a screenshot?
The Expose dialog did not really change in V5.
Post
by chriss0212 » 06 Jun 2016, 08:33
And here it is
- Attributes.PNG (6.33 KiB) Viewed 8901 times
Post
by Karol » 06 Jun 2016, 09:19
You are talking about exposings on Interface Containers!
No changes from V4 to V5 here neither.
Is it possible that you compare exposing on normal Containers in V4 with exposings on Interface Containers in V5?
Post
by chriss0212 » 06 Jun 2016, 10:48
in V4 it works ;(
greets
Götz_B
Post
by Götz_B » 22 Jun 2016, 16:10
it doesn't work if you try to set it for an interface container. But it works for normal containers AND it works on a Interface Container when you adjust it BEFORE you made the container interfacing,
Same in V4 and V5.
If you wanna know why.... we have to wait for Karol again
Post
by chriss0212 » 05 Jul 2016, 11:19
But if i uncheck interface and try it... still doesn't work. It only works until the container is set to interfaced first time.
Greets
Joe Styles
Post
by Joe Styles » 05 Jul 2016, 11:25
There is the same thing in the scene Data. When you make a clone (which duplicates the scene data) to get it to read the default you have to click the undo button on each instance.
Joe
Joe Styles
Kinetic Pixel
Götz_B
Post
by Götz_B » 06 Jul 2016, 11:20
Chris.... ähm.... no?
When I uncheck interfacing it works for me (with the latest release). Are you using a different Version? Do you want me to send a screen capture?
Joe, I don't know how your post relates to this topic.. ? But you speak of resetting the values, right?
