I had my Designer in Logic mode and did a "alt+enter" to make the renderer fullscreen. After switching back to design mode, the renderer was local again but the fullscreen remained in a stall. Even switching back to the logic view, it still has the renderer detached from the UI but the rendering doesn't seem to be 'restarted' fullscreen. Switching back to non-fullscreen and fullscreen also doesn't seem to resolve the issue.
Also I notice that toggling between fullscreen and in window causes a validation step to re-run on my scene that in my particular case takes quite a while. This validation step also does occur toggling between layout that had a fullscreen renderer (but as just mentioned, the renderer window remains in a freeze).
(validation apparently takes logs a lot of "ffmpeg warnings")
