Just tried to create a movie clip layer with a mask from another clip. Tried to scrub on the mask of the movie clip and needed to go front and backwards.
Editing the node using configure and setting "buffer all" doesn't seem to have effect. Also when the dialog is opened again it's back to normal. As a result I can only scrub forwards into the movie but not backwards. The reverse play option also does not seem to stick.
Movie clip layer cannot be set to buffer entire clip
Re: Movie clip layer cannot be set to buffer entire clip
sorry i cant reproduce this issue.
I created a 2dLayer MovieClip
Edit
Configure
set Buffer all
ok
Loaded a movie around 42mb
took a second...
and i can scrub without any problems..
even the configure dialog is holding the settings.
regArds
Edit
Configure
set Buffer all
ok
took a second...
regArds
Oh,
on my Windows 7 Machine the config doesnt hold the values too.
Was that a Win 7 Machine?
We'll doublecheck...
Götz
Götz
No my laptop runs Windows 10, will try to reproduce to show what really happens when the stress of my gig is over
Hey Sander,
we are investigating the issue aswell.
On my machine it did work at first.. after we tried to reproduce this, we had the same issue.
If you find anything which could help us: please drop a line
Thank you very much
Thank you very much
Tried to reproduce but it seems that it sometimes works and most often does not. But doesn't look like there is a real scenario for it to reproduce...
Fixed for 5.0.1
