strange thing,
i want to create a json string... for that i am using a toString node. one input should be a string array.... but how can i feed it in? if i use a string node behind the array... i will get a comma seperatted string... so far so good... but: if i have a string array with two values:
1st: hello
2nd hello world
you will get it like this:
hello, "hello world"
so second value gets "" why just the second string and not the first string?
string array in toText
Re: string array in toText
The "" come from the space!
And they are needed if you have a text like "one, two, three". These are not three strings but one! The commas belong to the string!
hi karol,
ok...got it.... but why dont you use always double qutes? this would make parsing easier and i could feed it directly into a json string array
