XML from URL
mixondigital
XML from URL
Hi All. I'm getting a live XML feed from a URL. Just having trouble getting the data in from a webpage. Any help would be greatly appreciated!
Re: XML from URL
What about the XML File node?
You have to Copy&Paste the URL to the 'File' property!
mixondigital
Re: XML from URL
Copy and paste into the file property window doesn't seem to work
Seems like it's trying to process, but when it's done, this is what ends up in the property window.
ventuz://Data/ta/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.IE5/FNS99VMP/meta[1].xml
Any other suggestions?
Re: XML from URL
works for me.
cheers,
works for me.
cheers,
- web_xml.vza
- (6.18 KiB) Downloaded 529 times
mixondigital
Re: XML from URL
It's all working now. How do I have the data update in Ventuz, if the data changes in the URL?
Re: XML from URL
Ventuz won't notice an update in a resource outside the local machine (where the file system offers a notification). And there is no update button for some reason. But you can bind the auto-update flag to a toggle and just hit toggle whenever you need to check for an update. It doesn't matter whether the auto-update is on or off, as it doesn't work. but toggling it will perform a refresh. If you need to know if anything changed, send the xml string into a string variable and use the changed event.
Best,
Best,
