I hope that you have in your road map this feature: several independent controllable template layer/channel.
Something to organize the show like this maybe:
1. Background
2. Main graphics
3. Overlay graphics
Robert
Multi channel for templates
Re: Multi channel for templates
What do you think about to refer to the scenes folder structure?
R
R
I used director a few time now and I feel that this tool is very fast and intuitive.
I've a lot of ideas about how to display and interact with this multichannel features.
What I like inside this tool is that we can quickly jump to differents reliables previews before cueing the one we need.
The playlist is nice too, I like to be able to skip one cue for another on the fly.
I didn't used the timeline because I don't understand the way you implemented it and in which situation I can use it. Maybe I will need it one day
My idea concerning the multi-channel is to have one show control ribbon for each channel on top of each other. Maybe we could click on each ribbon to see the properties of the preloaded template of the channel. Clicking on one ribbon could toggle its state and add It or not to the next "take". We'll need a shortcut to add or not all channel to next "take" maybe the "tabs/toggle" button.
For the playlist I'm not sure but maybe we'll need one column for each channel.
R
R
Ok, I understand that you need more use cases. I can share with you some usual situations.
It is mainly regarding PIP (picture and picture) display.
There is a principle you can find in every systems like Folsom Encore and Vista Spyder. If you "take" a new template with the same content as the program one but positioned differently, these systems will do an interpolation between the two positions. You won't see any "fade out" and "fade in" with the same content even if the content is positioned differently. It's look like a mistake if the fade out/in occur on air. This behavior is automatic.
Another principle is the quick swap between 2 templates. The operator press the "take" button and the template coming from the preview goes to the program and the one coming from the program goes to the preview within a cross transition.
The other automatic mechanism is the relative/absolute management of the content inside the templates. Imagine you have 3 pictures: pa, pb and pc. To the program there are pa and pb, to the preview there are pb and pc. Actually if you do a "take" in Ventuz, pa and pb will fade out and pb and pc will fade in. This is "absolute" change but "relative" change will keep pa and pb and will add pc to the program.
In every situation the operator need to be able to adjust the position of the PIP very fast and the spin editor is not optimal.
Regards,
R
Regards,
R
Alex,
I found my way with this little template concerning the automatic position interpolation. Used with the multi-channel features I think it will works very well. R
- PIP03.vza
- (22.85 KiB) Downloaded 1187 times
plkmarudny
The problem with a data marker and in general the way templates are handled is that animating between two values is not possible, only a hard cut. This is a serious limitation I am afraid. What if I want not just to move a picture like in the scene attached to this thread but also make a transition between both old and new values? A simple fade for example.
