V6.3.1 MXF audio error
SamTheSwede
Post by SamTheSwede » 07 Mar 2019, 14:31
We've just discovered that playing an MXF file with the Movie Clip node outputs a huge number of errors when the audio-box is checked.
These are the errors and the frequency of them is ~ 95 errors per second:
14:16 2019-03-07 Warning: ffmpeg: Wrong audio channels in audio frame: 1514880
Unchecking the audio box stops the errors from stacking up and eventually stalling the machine.
I am not sure if this is true also for a file that acutually has audio, but this was not the behaviour of V6.2
// Sam
Götz_B
Re: V6.3.1 MXF audio error
Post by Götz_B » 07 Mar 2019, 16:29
true, I can see the error message with mxf in 6.3.1, I don't in 6.3.0
But I do not see so much and the machine never stalls.
Could you send me a mxf clip that leads to a stall, just in case?
Does it also stall in a new simple scene that just has a movie clip? Otherwise it would be great if you could send the scene too.
Just send a wetransfer or whatever download link to support@ventuz.com
Götz_B
Post by Götz_B » 13 Mar 2019, 11:43
There was a little issue. It will be fixed in V 6.3.2
