Hiho,
is it possible to capture a touch driven scene and render it later to disk?
I need often the screen capturing when i move my scene with a touch transformation node.
Currently i use external tool but they can not capture highres touch scenes with more than 30fps.
Render to Disk feature for touch scenes
Twitter
Re: Render to Disk feature for touch scenes
Hi Tom
you can use OBS Studio for capturing in realtime! It is free and can capture directX streams! Very powerfull and free!
https://obsproject.com/de/download
Need some time for configuration... but very nice!
Greetings
Greetings
Hi Tom,
do you want to capture in Designer or during Runtime?
Hi Chris,
thanks for the link. I will check the tool
Hi Karol,
mostly i capture a movie in the designer to show clients how it looks. Presenter Mode would be also good if Its to difficuit in the designer.
Hi Karol,
Twitter
Hi Tom,
in Designer you can record the Touch Interaction with the scene (but only with the scene - not with the Designer UI):
https://www.ventuz.com/support/help/lat ... nderToDisk
Hi Karol,
yes i know i can capture interactivity in Ventuz but ...
when i make touch transformation it´s not storing the start position of first touch i did. It starts with my last position.
I can make a reset position but thats not very helpful mostly. Maybe its just the option to store the start position of the Touch Transformation what makes the difference
Also it would by great to capture optional the full ventuz screen with the Designer UI.
Best regards,
Tom
Best regards,
Tom
Twitter
