It would be nice, if we could enable/ disable send and recieve of ArtNET and sACN seperated by send/ recieve.
If we want to control Ventuz, Ventuz is also starting the server and is blocking the port. That way we can't start Ventuz AND the lighting desk software on the same PC what would be very handy for testing!
Greetings
Enable/Disable Artnet sACN
Re: Enable/Disable Artnet sACN
Send/receive is done via the same port, and it needs to be that way because Art-Net (starting from version 3) as well as sACN in multicast mode need some handshaking to support anything beyond basic DMX transmission. So separating send and receive wouldn't really help.
Apart from that - even if you would turn off sending, the explicit port numbers are mostly needed for _receiving_ DMX, so I don't see how disabling the send direction would help at all if you want to control Ventuz from a lighting desk.
That said, when Art-Net is used in Broadcast and sACN is used in multicast mode, the sockets are opened with the REUSEADDR flag; if whatever other software on the same computer plays along it should work.
Tammo
Tammo
Hi Tammo
i will check that
We tried using OnPC and Ventuz on the same machine and it wasn't working. Maybe wrong settings on our site
We already have an ArtNET Script because we are using ArtNET already a long time. This is working in combination with OnPC on the same PC
Greetings
i will check that
Greetings
