Yesterday i used one of our V-Boxes for a show with a lot of movie files - everything was fine.
But today the same system doesn´t play any videos with the mca-node (see Attache error-message)!
I have already reinstalled Ventuz - without success.
Any Ideas?
m
Movie Clip Advanced error
Re: Movie Clip Advanced error
So, what changed beside the day?
Is it still the same scene with the same Ventuz version on the same hardware?
mmahoni
The only thing that changed is that the v-box has internet access in the office
and get´s some windows and antivir updates...
After the first re-install of 3.06.00 i tried it with 3.06.01 without any success.
mmahoni
Hi Karol,
the ffmpeg DLL´s are located in the Ventuz Folder...
refuzee
this sounds familiar to me! i had the same a couple of days ago, actually no node pointed at the file the error message was about.
also i had some problems when changing the filename and importing a new (changed) movie with the same filename as one that was already imported. i always got an error when tryin to replace the file. quite uncommen though and can be fixed by simply renaming the new file
I have the same problem as mmahoni.
Someone found a solution ?
thiv
thiv
