is it right, that the Movie Clip Node has no Audio balance?
My actual workaround is to load the mp4 in an additional Audio Clip, but that is not totally sync.
Is there a better way to balance Audio in Video?
Greets
Ralf
Movie Clip -> Audio Balance
Re: Movie Clip -> Audio Balance
Hi Ralf!
You are right that there is no such Property.
Probably a better workaround:
You can use the Volume Control Node to balance the Output on an Audio Crosspoint.
To control the Balance of several Movies map different Ventuz Ordinals to different Cable Groups in the AV Config and play out the Movies' Audios on different Ordinals.
Best,
Stephen
Best,
Stephen
u-double-u
can audio balance be implemented for everything that can play audio, please?
