frontfacing culling plane Shadow Bug
Posted: 01 Jun 2021, 10:46
Hi guys
I found that when applying shadow on a 2 sided plane (Culling set to "none"), the shadow flickers when you cast the light from the back of the plane
Can you please test this from your side?
Create Floor and directional light with shadow, then create a rectangle with material draw mode (Draw All Faces / Culling:None) and pitch the light about 140 degrees.
