Webm with alpha not working
remi_agi
Post by remi_agi » 01 Aug 2019, 10:10
Can you check the webm codec ?
Alpha channel doesn't work.
My test file : https://simpl.info/videoalpha/video/soccer1.webm
Thank you
u-double-u
Re: Webm with alpha not working
Post by u-double-u » 05 Aug 2019, 10:16
from what I read about Webm/VP9 the alpha channel is/was more or less an experimental feature only running in chrome.
I‘d use Animation Codec or HAP.
remi_agi
Post by remi_agi » 06 Aug 2019, 09:55
Hello u-double-u
this feature is not expiremental !
ventuz supports this codec
https://www.ventuz.com/support/help/lat ... nelSupport
u-double-u
Post by u-double-u » 06 Aug 2019, 10:46
oh, but the internet told me so... How do you encode it? Adobe Media Encoder?
Adobe is dropping and changing support for things all the time...
Post by chriss0212 » 22 Aug 2019, 10:12
Mhhh...
Same problem. I am using Adobe Media Encoder to export to webm with alpha enabled, but no alpha in Ventuz.
Could you please check, if alpha is supported in Ventuz?
I am using this Plugin for Media Encoder:
https://www.fnordware.com/WebM/
Greetings
Christian
remi_agi
Post by remi_agi » 29 Aug 2019, 09:10
Ventuz, I need your help...
lerou
Post by lerou » 29 Aug 2019, 09:32
remi_agi wrote:
29 Aug 2019, 09:10
I wouldn't rely on the Ventuz Forum....
Have you sent an email to support@ventuz.com?
remi_agi
Post by remi_agi » 29 Aug 2019, 16:43
lerou wrote:
29 Aug 2019, 09:32
remi_agi wrote:
29 Aug 2019, 09:10
yes, I do a bug report
Post by Dennis » 13 Sep 2019, 10:57
I will forward this to Karol .. maybe he can help you or point you into the right direction..
