OPT command not implemented in VMS
Eric_RD
Post by Eric_RD » 10 Dec 2018, 12:02
So I was configuring Remoting for a V6 installation and discovered that the OPT command is not working in VMS V6 (Port 20405)...
220 ServiceReady [49]
VMS - Ventuz Machine Service ready - [6.2.0.40]
OPT .REN.Stats True
502 NotImplemented [30]
Command not implemented: OPT
OPT .REN.Stats False
OPT .REN.Wireframe
It should work as described here: https://www.ventuz.com/support/help/lat ... tm=311#OPT
Also the Port in the VMS Manual is incorrect it says 19405 instead of 20405: https://www.ventuz.com/support/help/lat ... wtoconnect
I would like to toggle the Statistics and Input Diagnostics via simple TCP commands with Universe Show control...
