Scene Event bug?
momentum
Scene Event bug?
Post by momentum » 15 Oct 2018, 16:19
I'm setting up a series of scenes to show in a sequential order. I created a Switch layer which contains a series of Scene Layers to load current scene. Each scene will have independent animations for transitioning in/out and some ambient animations which are unique to each one. I'm using the Scene Event node to activate the "transition in" animation and it doesn't seem to want to fire when the Switch Case value is changed to the scene I would like to display.
According to the documentation, it seems this should work, but it doesn't.
If this isn't a bug, is there a standard way to do something like this? Should I look more towards using Template Layers?
momentum
Re: Scene Event bug?
Post by momentum » 15 Oct 2018, 16:56
As a side note, the slides may not have a fixed display time. We will be feeding content externally which may include videos of varying length.
momentum
Post by momentum » 15 Oct 2018, 17:02
Hmm. I just rebuilt it and it worked. Strange, please ignore this post.
