Texture Output C#
sribas
Texture Output C#
Post by sribas » 11 May 2020, 13:18
Is it possible to get a texture output in c# scripts ?
it takes a lot to save bitmaps locally, for bypass it...
Re: Texture Output C#
Post by Dennis » 11 May 2020, 15:38
Hey, its not c# but did you check the "texture saver-" or better the "snapshot" nodes?
Have a look at the documentation or the interactive help, by pressing F1 while you hover over the nodes ;)
sribas
Post by sribas » 12 May 2020, 15:49
"texture saver-" or "snapshot" are limited to Node/Viewport use.
It will be more interesting to generates textures from c# and directly connect them to nodes.
Example :
if i would like to get videosource from Aforge in C#, and output rendered texture to Ventuz texture.
