Is it possible to get a texture output in c# scripts ?
it takes a lot to save bitmaps locally, for bypass it...
Texture Output C#
Re: Texture Output C#
Hey, its not c# but did you check the "texture saver-" or better the "snapshot" nodes?
Have a look at the documentation or the interactive help, by pressing F1 while you hover over the nodes
regArts
regArts
"texture saver-" or "snapshot" are limited to Node/Viewport use.
It will be more interesting to generates textures from c# and directly connect them to nodes.
Example :
if i would like to get videosource from Aforge in C#, and output rendered texture to Ventuz texture.
Example :
