Import C4D X-Particals settings live
C4d has a very powerful partical plugin called X-Particals which can simulate huge kind of objects with  preset. Will Ventuz add a particle-import-live note for c4d particals.
						Re: Import C4D X-Particals settings live
Hi hanjanjie,
we currently do not have such plans.
Hey Hansanjie,
well you can use XParticles and create your simulations and use the LiveLink to get your simulation in to Ventuz.
In most cases you would need to use the "Connect" modifier on tob of your Hierarchy on Cinema side, to get a real "Mesh" which can be imported into ventuz.
You can then also bake the animation on the Cinema side to have it a s a meshanimation in Ventuz.
RegArts
RegArts
