Directory Node Folder Count & Names
Naggar
Post by Naggar » 14 Nov 2018, 13:15
Hello
I'd like to request an update on the Directory node..
if possible,in addition to file count, could we get folder count and/or folder names Array?
Naggar
Re: Directory Node Folder Count & Names
Post by Naggar » 14 Nov 2018, 13:17
or if it is possible to search for Folders through the search pattern property, that would be a nice workaround.
joschy
Post by joschy » 16 Nov 2018, 14:45
you can do it by your own with scripting check C# Directory.GetDirectories.
There are many example codes on the internet ;)
Naggar
Post by Naggar » 06 Dec 2018, 11:42
yeah that we ended up doing.. but again, im not really good with codes and scripts. so I had to get a programmer to do it for me...
Thanks though :)
Eric_RD
Post by Eric_RD » 23 Dec 2018, 15:35
It is even possible with a String Expression...
I think it might already be in the forum...
Pros for String Expression:
no compiling on startup needed
Cons for string expression:
No async functionality
Remember to always write the full class names in Expressions (System.IO.Directory.GetDirectories...)
Post by chriss0212 » 23 Dec 2018, 18:01
Because i am also not the best scripter on earth i tried a little workaround ;)
You "just" need to copy a file with the same name into every sub directory in the tree... in my case i used dummie.txt. at the end you will get all sub directories as an array.
No scripting, no async problem... as long as the dir node has no async bug ;)
Greetings
GetFolders.vzs
(7.57 KiB) Downloaded 10 times
