Hello guys,
I would like to create contents dinamically, like spread do, but i need to control each items inside, independently.
I don't know if it's possible in Ventuz ?
Node dinamically
Re: Node dinamically
nope. You can't dynamically create nodes. Ventuz is a very static tool when it comes to its hierarchy. You can only create a maximum amount of containers and then use the required number. As for container content, you must build a general container that adapts to your needs (in terms of parameters). Using too many nodes will crush your CPU performance, though.
