How to recognize multi touch in Particle System
tuna_627
Post by tuna_627 » 08 Nov 2019, 07:14
I want to recognize multiple touches ( or positions) in Particle System by touching screen.
In Particle System, I can generate multiple particles using trigger burst in source module,
But I cannot make particle like interactive contents with multiple touches by using force and gradient module.
For example, Particles can only avoid one sphere like image,
But Particles cannot avoid two ( or more ) sphere, because manual transform in force module only have one position.
How can I have multiple interactivity for one particle system?
does anybody knows ,please let me know, thank you!
Re: How to recognize multi touch in Particle System
Post by Dennis » 08 Nov 2019, 10:05
Hi and Welcome,
i have deleted your "test post" by the way...
Anyway:
Use a second Force, and bind its translation to the second touch...
A wise idea is to use an Anchor Node and Anchor as transform.
You can check if a touch occours and "block" the forces for the moments where no touch happens...
RegArts
:ugeek:
tuna_627
Post by tuna_627 » 08 Nov 2019, 10:47
Denis
Thnak you for replying!
I posted a " test post" for vertification. Sorry...
No problem to delete.
I get the point.
I will try according to your instruction.
regards
tuna_627
