Triggering Touch Objects with Keyboard Input
Posted: 24 Oct 2019, 16:22
Hey Guys
Bit of a new user here, but I have an application that uses touch objects as targets via a touchscreen. Think of something similar to a dartboard.
The user throws a ball at the screen target which registers a hit on a touch object, but in case the touch screen doesn't respond quickly enough (and its an obvious hit) I need to be able to have a moderator hit a key on the keyboard to trigger the selected target.
I've tried using Keyboard inputs but the direction in the hierarchy is wrong.. I need it to accept a keypress input and trigger a touch object instead of the touch object triggering a keyboard input.
I'm sure this is pretty simple but I'm just not seeing it right now. Any thoughts?
