Combine Touch Pattern and Touch Paint Node
Posted: 24 Jul 2019, 16:20
by cogitator
I'm struggling with combining the Touch Pattern and the Touch Paint Node.
When using both nodes with the ScreenAligned option checked, I get all gesture events of the pattern node and can see the touch-movement-strokes for the hole screen.
I want to use this only on a specific rectangle/geometry.
Thanks for your help in advance!
David
Re: Combine Touch Pattern and Touch Paint Node
Posted: 27 Jul 2019, 22:48
by u-double-u
Hi, what do you want to do? Position and scale a rectangle/geometry and then paint on it?
Posted: 28 Jul 2019, 14:34
by cogitator
u-double-u wrote: ↑27 Jul 2019, 22:48
I want to build a virtual touchpad(appletv remote) which detects touch gestures (swipe left/right/up etc.)and visualizes the touch-finger-movement.
Posted: 20 Aug 2019, 15:44
by hgoodsir
Hey this is made in version 5 quick scene but should apply same way in v6, you can swipe gesture and see the paint effects
https://drive.google.com/file/d/1Vd1fQo ... sp=sharing
Posted: 03 Sep 2019, 09:22
by cogitator
Thank you for the scene and sorry for my late reply.
The problem is that i want to use the Touchpattern/Touchpaint node only in a specific area of the canvas(defined trough a rounded rectangle).
