How make this button effect ?
eguana
Post by eguana » 04 Jul 2018, 20:03
I have 6 buttons.
When I once click on any button, it becomes active. When I press the second time, the button goes to the normal state.
When I press the button, the other buttons should go into normal state, they must be inactive
How disabled other buttons, i don't know, please help. I use logic toggle, switch, value.
Ventuz scene
Joe Styles
Re: How make this button effect ?
Post by Joe Styles » 05 Jul 2018, 09:39
Hi Eguana,
If you use containers you can pass out the container index which will let you know which button has been pressed. Using logic you can then toggle it back off again. I've attached a scene to illustrate.
Hope that helps!
Joe
ButtonsExample.vzs
(24.96 KiB) Downloaded 199 times
Joe Styles
Kinetic Pixel
Post by Dennis » 05 Jul 2018, 10:06
or enjoy this...
Button_Logic_2932.vza
(22.09 KiB) Downloaded 214 times
eguana
Post by eguana » 05 Jul 2018, 10:47
Joe Styles wrote:
05 Jul 2018, 09:39
Hi Eguana,
Hope that helps!
Joe
Joe it is best logic with index.
I suffered yesterday how to transfer the index when the button is pressed. Thanks for the great idea.
