linear Path animation
Post by chriss0212 » 28 Jun 2018, 13:55
Mhhh...
is there something i miss in the path animation? I would like to make a path animation with the path length or moving a texture... but if there is a corner, the tesselation is changing what results in speeding ub or down the animation.
Is there any way to make a linear animation of a path with sharp corners?
Greetings
stephen
Re: linear Path animation
Post by stephen » 28 Jun 2018, 15:11
Hey Christian,
have you tried the Subdivide Path Node? This should help doing it.
Best
Stephen
Post by chriss0212 » 28 Jun 2018, 16:17
Hi Stephen,
i used the arrow pass because of adjusting the thickness. Now i using the normal Path node and i am doing the thickness by adjusting the line thicknes in the material. Is MUCH better now!
Greetings
