C# script : STATIC class
All other topics about Ventuz 6 here.
MATIM
Post by MATIM » 31 Aug 2020, 08:19
is there a way to use static class and variable with the c# script node in Ventuz.
I try to instanciate a cluster variable in a c# script node
then access this variable between severals c# script node in my project.
Is this possible ?
Mat.
Re: C# script : STATIC class
Post by Karol » 31 Aug 2020, 12:08
Hi Mat,
unfortunately this is not possible.
sribas
Post by sribas » 31 Aug 2020, 13:18
You can try to output variables from others scripts and inject them into main script.
But it will be simplest to regroup everything into a same script.
