Geometry renderer - Skinning
All other topics about Ventuz 6 here.
joschy
Post by joschy » 29 Nov 2018, 09:56
Hi there,
i have one question. What is the parameter Skinning under the Geometry Renderer Node good for?
Haven`t found anything in the docs.
tia
stephen
Re: Geometry renderer - Skinning
Post by stephen » 29 Nov 2018, 10:21
Hi joschy,
you can bind that to the output of the newly introduced Animation Rig node. You can import a skeletal animation using the glTF format. When imported Ventuz will create a vzrig file that you can use in any Animation Rig node.
We will update the documentation, so this becomes clearer.
Best
Stephen
joschy
Post by joschy » 29 Nov 2018, 11:15
thank`s for the quick replay
:thumpup
