Download Public Beta 2!!
Posted: 12 Mar 2018, 10:19
Hello Hello Ventuzians,
a brand new Beta has been released!
You can
DOWNLOAD HERE the golden piece of Software
As usual your feedback is more than welcome! We need YOU to make the world a better place and the software way better than before.
Keep in mind to delete and reinstall the C4D Plugin!
Happy testing...
reg
Arts
Re: Download Public Beta 2!!
Posted: 12 Mar 2018, 16:56
by rcanthony
Sadly Beta2 release doesn't launch after installation on my system I can't seem to launch the executables in the Ventuz6 folder in Program Files or force any command line options on Ventuz.exe to get any result. Uninstalling Beta2 using 'add/remove" and then Reinstalling Beta1 reverts me to a working Beta1 without any issue. Is there any data I can share about my config that would be helpful?
A note about my installation process that may help identify the issue is that when installing Beta2 it prompted me once again with the migration assistant dialogue and I selected the options as before... maybe this was an error on my part?
Posted: 13 Mar 2018, 14:01
by Maecki
I have the same problem with Beta2.
Install Beta1. Works fine.
Greetz//Marcel
Posted: 13 Mar 2018, 14:18
After an unsuccessful start of Beta2 please go to Computer Management and check the log entries in 'Event Viewer->Windows Logs->Application'.
Is there any entry for Ventuz and what does it say?
Which OS are you using?
Rest Regards
Posted: 13 Mar 2018, 18:19
by Maecki
Hi Karol,
after deinstall Beta2, install Beta1. Set the Licence Key. Deinstall Beta1 and again install Beta2, Beta2 works.
Greetz//Marcel
Posted: 14 Mar 2018, 18:59
by shermanpat
Just installed Beta2 (publicbeta_60) I had not installed Beta1 (publicbeta_12) had Ventuz 5 installed.
Can't start Ventuz X Designer or License manager, I can open Config Editor but it can't reach VMS saying object reference not set to and instance of an object.
Tried removing V5 and VX and remove some app data folders, reboot and install Beta 2 and get the same issue.
Going to try Maecki's steps and see if install Beta1 setting the license then remove beta1 and install Beta2 works.
Two Application errors which seem to point towards a License issue when I open Designer:
Application: Ventuz.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.NullReferenceException
at Ventuz.License.VerifiedLicense..ctor()
at Ventuz.License.VerifiedLicense.([])
at Ventuz.License.LicInfo.VerifyLicenses(Ventuz.License.Product, System.Tuple`4<Int64,Char,Int32,Int64>[])
at Ventuz.License.LicInfo.InitializeProduct(Ventuz.License.Product)
at Launcher.MainProgram.Main(System.String[])
Faulting application name: Ventuz.exe, version: 6.0.0.60, time stamp: 0x5aa29966
Faulting module name: Ventuz.License.ni.dll, version: 6.0.0.0, time stamp: 0x5aa29940
Exception code: 0xc0000005
Fault offset: 0x000000000015c3c9
Faulting process id: 0x54c
Faulting application start time: 0x01d3bbbc4acc8f5d
Faulting application path: C:\Program Files\Ventuz Technology Group\Ventuz 6\Ventuz.exe
Faulting module path: C:\Windows\assembly\NativeImages_v4.0.30319_64\Ventuz.License\3f920a195a50405431e2678ea39b6fac\Ventuz.License.ni.dll
Report Id: f7e71de0-d4cb-479a-bb21-3660674dd358
Faulting package full name:
Faulting package-relative application ID:
Posted: 14 Mar 2018, 22:22
by shermanpat
Working now, here was my process.
Uninstalled Beta 2
Installed Beta 1
Applied licence
Opened Designer
Uninstalled Beta 1
Installed Beta 2
----Now this is the step that I think was the issue in the first Beta 2 install for me.
Migrate Data window with Migrate licenses selected
Now all good to go.
Posted: 15 Mar 2018, 08:15
This helps a lot!
Thank you very much sherman.. i will forward this to Karol!
Really appreciated and best reArts
Posted: 15 Mar 2018, 14:38
by stephen
Hey guys,
thanks for all the information provided to track this bug.
Actually we had that fixed already but because of interferences in timespace it did not appear in the release.
I have updated the download link in the initial post of this topic. You can just download that new version and install it. If you had the previous Beta2 release installed you might need to de-install it first using the Programs and Features Dialog of Windows.
If it is still not working on your side please let us know!
Thanks again for this and have fun playing with the new version!
Stephen
Posted: 15 Mar 2018, 19:04
by shermanpat
Always happy to help. I have been pretty busy and haven't had much time to play. But so far really like the new features and the direction things are going.
I did have a bug that I was not able to enter text when using the spacebar toolbox shortcut in alphabetic mode. I did have my windows scaling set to 150 and meant to see if it was something related to that.
