In Ventuz 5, we could easily enable/disable effects in layer view since all the effects were nicely listed and we could quickly once-click enable and disable any of them. Now in V6 you changed it, so now you have to open every effect separately to be able to activate/deavtivate it. That is counterproductive. If you can make the shortcut ACTL+A work on Layer view as it is working in Properties, it would be much more intuitive and better
Enabling/Disabling effects in Layer view
Re: Enabling/Disabling effects in Layer view
Hey, thanks for the report! A ticket is created, we will fix that.
Please bring back the "old" FX- switch for on/bypass, delete and change order (up/down).
This was so cool, easy/quickly to work with and screenspace-saving.
cheers
cheers
