Just another feature request - garbage matte
A protected forum section for the public beta of Ventuz version 6.0
u-double-u
Post by u-double-u » 18 Apr 2018, 09:45
once I am at it, what about adding a garbage matte effect for layers AND nodes, where one can add another node or splines or maybe draw a matte? This would reduce the need for „crop“.
Re: Just another feature request - garbage matte
Post by Dennis » 19 Apr 2018, 10:19
Ahoi,
the garbage mtte option can be found here:
this obvs works only when using an external chroma keyer or the internal soft chroma keyer config.
u-double-u
Post by u-double-u » 19 Apr 2018, 11:26
weird, I dont have that button anywhere in Version 6 Beta 260 R21349
Plus, I don‘ have a soft chroma keyer, I just have the Color difference Keyer.
Or is it me...
cheers
Post by Dennis » 19 Apr 2018, 11:53
Yes sorry, you are right.. with the Beta you are not able to test the matte feature since the key has no broadcast option.
You can check and test the Garbage matte feature still with V5. We did not change a lot to that particular feature therefore you would need to test out that features seperate from each other.
(you still would need a broadcast option to be able to test it with v5)
all the best
u-double-u
Post by u-double-u » 19 Apr 2018, 12:40
oh, i see, all this is in the broadcast version.... Can we get a garbage matte effect in the „normal“ version then? Please?
