touch button with director
mixondigital
Hi all. I've built a scene that I'm current controlling functionality with touch buttons. I now want to use this template, with others to play out with Director. Is there a way to enable the touch buttons while using director?
Re: touch button with director
Hello mixondigital,
I had the same issue. It does not seem that you can interact with the channel and program view inside Director.
A workaround is to start Presenter/Runtime on the same machine and then to control it using Director. The touch will work inside the Presenter/Runtime.
You could also use the renderer inside Ventuz Designer but I haven't tested that much using this method.
Daniel
Professional 3D Integrator
