Problems encountered with touch paint node
Posted: 27 Mar 2018, 13:58
by lfchenc
hello ventuz,
I used ventuz's touch paint node in a project and I found that if I disabled ScreenAligned, then I wouldn't be able to use the render target ,if I enabled ScreenAligned so that I could use the render target in this mode.So I need to adjust the Layout to Percentage. In this case, I have to dynamically adjust the x, y, width, and height of the Percentage. I find that if I bind X, Y to an expression,it works. However, if I bind Width and height to expressions, it will not work properly. No binding it work also. Is this a bug? Thank you
