Font Render Error
robertwinter
Font Render Error
Post by robertwinter » 11 Jun 2017, 04:10
I'm using a font called Soup of Justice. Available for free here - https://www.ffonts.net/Soup-of-Justice.font
I'm getting render errors on the letters K and S. I've attached an example of the output.
I'm using 5.1.1 but have verified the problem still exists in 5.3.
Re: Font Render Error
Post by Karol » 12 Jun 2017, 09:46
Thank you for the report. I will create a bug ticket for that.
In the meantime you could disable the 'High Quality 2D Text Rendering' in the Machine Configuration to overcome this problem.
robertwinter
Post by robertwinter » 17 Jun 2017, 00:35
Can you direct me to where that setting is located? I must be overlooking the obvious.
robertwinter
Post by robertwinter » 18 Jun 2017, 16:43
Took some digging, but I finally found it.
