Node Workflow Suggestion
dotajink
Post by dotajink » 10 Nov 2017, 04:10
Does ventuz can modify the way that you want to expose the property, such as : set a name directly through a node and specify the required attributes, and when a place needs the properties of an object, just through a node to directly index the demand Name then you will be able to get all its attributes
