Hey guys!
I'm willing to add a htc vive tracker to ventuz to track objects but I don't know how to link it to ventuz
I tried as controller or reference but nothing happened
So what's the right way to add a htc tracker to ventuz ?
here's the link of the tracker:"https://www.vive.com/eu/vive-tracker/"
HTC Vive tracker doesn't work!
Re: HTC Vive tracker doesn't work!
The Tracker works, you need to use the reference and increase the ID to match it to the Trackers ID.
First set it up in the SteamVR environment and make sure its recognized there. Then use it in Ventuz.
But its working, since i use it personally as well and for Camera Tracking fun
VincentPix
The Vive Tracker is working fine if I've the output on SteamVR but no tracking if I want to display on my Nvidia output. Is there a way to get around ? (I tried a "No HMD" config)
Vincent
Vincent
u-double-u
Male sure the trackers you use are matching the „lighthouses“ and HMD. I once rented some Vive Pros to try them out but just had my „old“ first generation trackers. They would pair but not track. And they would shut them selves off after a few minutes of inactivity. So I had rented the stuff for nothing but this knowlegde...
The old trackers are the ones with the grey Icon. the newer ones have a blue one.
