[Fatal ]: (Director|UnhandledException) Unhandled exception: UCEERR_RENDERTHREADFAILURE
Posted: 13 Nov 2018, 20:46
Hey!
when I run director, sometimes it shows an error but sometimes not
I,m using 3 virtual midis and 2 outputs
my outputs are decklink quad 2 and decklink 4k extreme
this is the error
So whats the possible issue which making this ?
[Fatal ]: (Director|UnhandledException) Unhandled exception: UCEERR_RENDERTHREADFAILURE (Exception from HRESULT: 0x88980406)
<Exception Type="System.Runtime.InteropServices.COMException">
<StackTrace> at System.Windows.Media.Composition.DUCE.Channel.SyncFlush()
at System.Windows.Interop.HwndTarget.UpdateWindowSettings(Boolean enableRenderTarget, Nullable`1 channelSet)
at System.Windows.Interop.HwndTarget.UpdateWindowPos(IntPtr lParam)
at System.Windows.Interop.HwndTarget.HandleMessage(WindowMessage msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Interop.HwndSource.HwndTargetFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)</StackTrace>
<ToString>System.Runtime.InteropServices.COMException (0x88980406): UCEERR_RENDERTHREADFAILURE (Exception from HRESULT: 0x88980406)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)</ToString>
this is the error
