Hey!
I have a question about how to switch from integer to boolean
To clarify, for example: when my int is {0} so the bool is {no}, but when the int is 100 so the bool with be {yes}.
switch from int to bool
Re: switch from int to bool
Put your int into a bool variable. 0 = false, everything else = true.
Or use Bool Expression
Connect your int to "A"
and change the Expression to
(Bool Expressions are quite nice because they also give you two event outputs (True, False) with every validation. This saves a lot of event nodes and inverts. Plus You don't have to write the output values like "A==100?1:0" in an Int Expression because there is just true and false)
A==100
