Auto resize rectangle size with text length
Re: Auto resize rectangle size with text length
Postby ahmedahmed1223 » 14 Jun 2017, 12:18
Thanks Lerou :D
if you use shrink 2 fit, that effect obviously changes the bounding box. It also has a parameter for the bounding box type - but it does not output the new bounding box. I'd suggest asking Ventuz support to implement that feature - unless I'm missing something.
Hope ventuz implement this feature in future release.
ahmedahmed1223
Postby Christian Krix Schmidt » 14 Jun 2017, 14:40
Right to Left does not matter to Ventuz. Everything works exactly the same in Arabic. Just make sure that you select "RightToLeft" in the Block Text node.
Previous
Return to How to
