creating 360 render target of scene
Posted: 03 May 2017, 09:34
Dear Ventuz Team
I'm working on a project which requires me to project a 3d environment inside a physical "cube" room. This project involves camera animations in my 3d environment.
For now, considering only the front, left, and right walls of the cube, I thought about creating 3 layers in a canvas of 5760x1080 and each layer is 1920x1080 aligned next to each other.. the three layers have the exact same scene, but the left and right layers have cameras panned to 90 and -90 degrees. This approach doesnt seem to work though because of the FOV. I can adjust the FOV manually to get the layer edges somewhat aligned with each other only for still cameras but not for animating cameras.
So I was thinking.. is there a way to make whatever scene I have into a 360 render target (Cubemap)? I am aware that there is no 360 camera available in Ventuz but is there a way I can adjust one or multiple cameras to achieve this result and then create a render target, or any other solution would be appreciated.
Thanks and best regards
