layout scene can not put a template layer
lfchenc
Post by lfchenc » 21 May 2017, 11:15
hi,
I I found a problem when i used Ventuz5 ,i want to control the templates with director,and also use ipad to change the template,In v4,i can put a template node in the layout scene,
but in ventuz5 i can't put a template layer in the layout scene,how can i do that in ventuz5? thanks for your help.
Götz_B
Re: layout scene can not put a template layer
Post by Götz_B » 02 Jun 2017, 09:29
first of all, if you want to control template with director, you just need scene layers/ports in your layout scene. You only need template layer when you want to control templates by yourself - for example in the scene logic.
Second, the issue that you cant put template layers in the layout scene is fixed now in V5.3.1
